Quote:
Originally Posted by
Dxs
The honda way is to let the steering pump, pump out all of the fluid with a hose off.
That's basically what I did, without letting the pump run dry, which tends to ruin seals & bearings
Quote:
The general knowledge is honda coolant should be used as it does not have silicone additives.
That's not a unique Honda trait and coolant has moved on a bit since 2004.
The Honda Type 2 fluid is just a 50:50 OAT (Organic Acid Technology) premix consisting of
1) Ethylene Glycol 47-53%
2) Diethylene Glycol <3%
3) Potassium Hydroxide <3%
4) Hydrated inorganic acid, organic acid salts <5%
5) Bittering agent >30mg/kg (Added so you don't eat it)
OAT coolant has been in common use since the mid-90s in Honda, Toyota, Nissan, Mazda, VW/Audi, Jaguar, etc.
Penrite, Nulon, etc all make compatible OAT coolants that meet or exceed the Honda Specification and sell for a cheaper price.
Quote:
Also power steering fluid should be honda as well.
If it meets or exceeds the Honda specification, why wouldn't you use Penrite HPSO?
In this case it complies with Honda PSF, Honda PSF-II, Honda, PSF-S & Honda PSF-V and is compatible / mixable with the OEM fluid. It will be fine. In fact, I've done a few km since yesterday andthe steering is beautiful. All kick-back gone
Quote:
There are online parts places like OEM Acura Parts which has part diagrams and posts to Australia. Generally it is better to spend a bit more on genuine parts.
Great. Thanks
Quote:
I would also check the engine mounts. Might explain a few things.
Still coming. Ran out of time
Quote:
edit: In terms of isop alcohol, it is a single substances that evaporates, leaving nothing behind. Stuff like cleaners and greasers often have detergents etc which will leave traces of stuff.
Sure, if it was a MAF that doesn't like contaminants but it's a throttle body & inlet manifold. The ideal cleaner is throttle body cleaner.
