ngk normal plugs like $3.5 each from repco. Honda are easy to change just change plug every 40000km. feel a little more responsive.
don't waste money on iridium. Unless u own a wrx or ej 20, that a differnt story.
I agree about the Champion Plugs they are "SNOT" i paid 17 clams for a set of 4 for my 1.6ltr and tossed them after about two weeks cause the plugs had fouled something shocking(electrodes broke down NEVER LOOK AT THEM GAIN! CHAMPION = LOSSER).
Went to local parts dude and got NGK-BCPR6EY-11 ( paid 2.50 a plug)car ran sweet once i reset the ECU.
The main part is the -11 number refers to the electrode point which has a V in it, that produces a wider spark in the combustion chamber which inturn ignites the fuel better.
Also the Iridium plugs were around 22 clams when i purchased my new NGK's and friends who do a lot of driving swear by them, in respect to the 100K, slight extra performance and fuel economy, not that any of the rev-heads on here would be concerned about fuel economy :-).
About leads which I thought of changing aswell, but first rang the Honda dealer for a price for OEM's, which he gave me then said why do you want to change them, as for all of my model engine's they had never, and he did stress never, replaced the original leads for my model car yet( they have been on for over 15 years)
The only honda leads that do need replacing was mainly on Legends around every 10 years give or take.
Also if you still are concerned about the leads get them tested
hope this has helped.
Quote:
Originally Posted by SIKCVC
do u mean '6 being hotter running plug' as in smaller number better?
anyone knows which is better?
NGK
BKR5EIX-11 or BKR6EIX-11 ??
i got iridium plugs from NGK for a b16A and i was quoted 50,000KM before i neeed replacement?
are u guys just overly pedantic for replacing every 10,000KM or is this actually necesary?
yeah champion arent that grat.. pls try and stay away from them u'll end up with little annoying problems..
i've heard somewhere denso was made by ngk..?
also denso stuff is quality
to change the spark plug gap.. u gotta get a wire feeler gauge for it.. it's got little loops of wire each with different sizes.. 0.86mm 0.89mm etc etc..
and u pass these thru the spark plug tip it should be able to slide in with minimal obstruction..
it's got a little tab u can use to open the gap up a bit wider as well..
BKR6EN-11 - Highly recommended, affordable and performs well for everyday driving
BKR7EN-11 - Next on the heat range (colder) use for high speed driving i.e possibly racing...
The Iridiums perform well too, just much more dearer... I like the idea of having fresh new plugs each service plus the coppers are so much more cheaper...
As for the gap they are pre-gapped 1.1mm (hence 11)
FYI
http://members.datafast.net.au/~teet...ksparkplug.jpg
how bout NGK iridium BKR5EIX-11 ... anyone knows? :)
as the diagram shown.. BKR 5 EIX-11 the number smaller = hotter. bigger = colder. is hotter better or colder better? :rolleyes:
thanks :wave:
I used NGK Id before. I am using OWS spark plug now. I feel OWS a bit better than NGK Id.
Here is a illustration from NGKQuote:
Originally Posted by STTICH
http://www.ngk.com/glossaryImages/93.jpg
Finding the right heat range for the right application...
One of the primary purposes of the spark plug is to remove heat from the combustion chamber, it does so by transferring that heat to the engine head.
You dont want the plug too cold otherwise the the carbon deposits will remain and wont burn off over time and will foul the plug....
You dont want a plug too hot otherwise pre-ignition of fuel causing detonation
So the aim is to find the balance
For more reading information go here
http://www.ngk.com/faqmain.asp
And for those with S2000's
I recommend using the NGK V-Power R5672A-8 (8's)
for Accord
Your Vehicle:
1994 - on Honda Accord 2.2L E.F.I F22B1, F22B3
Spark Plug Part No. Plug Gap
Recommended Plug ZFR5F-11 1.1
Iridium Option ZFR5FIX-11 1.1
i would prefer NGK Iridium plugs and replace them on every 40,000 Kms. for me thats 2 years. not bad to spend $80 on spark plugs after every 2 years.
I've used BERU spark plugs before, goes for like 11 dollars each and have no issues with them..
from where did you buy them?
are they UltraX?
