not sure what u mean about gauge lines
but the end of the compression tester wont screw in where the spark plugs usually go...
will the temp of the engine vary the read outs?
better to be done when its COLD or WARM
yes - at COLD the engine will sometimes give varying compression results ( carbon and very slight dimension differences etc ) But once the engine is at operating tempreture - compression should not vary with +/- 5% of each cylinder. That is , best result = at warm :)Quote:
Originally Posted by SKREMN
Errmm......
What is the situation with injectors and fuel in this procedure ? ;)
a big 0 since its all disconnected lol :confused:Quote:
Originally Posted by ProECU
Yeah True
I should learn to read gooder...
with my build up-b18c block-ctr pistons and b16a head- i broke in my engine where at 1000km's i tested it...
i read something like 240-225 psi... would you guys think that the compression is too variable?? if i remember how to do my maths right the +/- is variable is about 6.5% differance!
would this efect the tuning and timing or perhaps cause one cylinder to have pre dettanation while the others didnt??
lol i dont want to reseat the rings....mabey i should just close my eyes to it and keep driving coz it runs sweet! just pretend i didnt do the test in the fiorst place;)
I think you should re-try the compression test.
I would be concerned with those numbers you posted...
It might be a case of still requiring to run th emotor in further.
I'd keep an eye on it, and recheck the compression later down the track.
will do :)
I will have to do a leak down test to get a propper diagnostics i think
whys all the pictures the same, a civic
considering u bumped a thread thats almost 5 years old
im thinking the images arent on the server anymore
yea obv lol. just pointing out it should be changed :P
