200 dollars shipped...thats bang for your buck perfomance value there.
hey Weq, was that bought from america or over here? Looks real neat by the way
it did the job tho yeh weq??
was it an actual shop or private seller?
is it true that if u buy a lot smaller Apexy "i forgot the specific name" I/C that it can cool alot better with practicaly no restriction?
yes it would be alot harder to find and alot more than 200bks shipped
(i dont hav a dollar sign on this cr%ppy euro keyboard :)
wat kind of performance could i expect from one of those sexy black i/cs?
would it be very restrictive past 20psi? and dose spraying ur i/c with water or nos before a run realy do anithin?
spraying water over the i/c merely makes the air temp when passing thru the i/c cooler.
edit: nitrous is a different application but still the same concept
yes it was local. the guy is on ebay. i think he sells em for around 250 now, but he does the occasional $1 auction which is when i picked it up. we will see how much boost it can handle though, im pretty sure it should handle under 18psi no without becomming a restriction. for a stock bottom end setup, this is a perfect fit with just a bit of trimming required.
the core itself is just ur average chineese thing (like all the other copy intercoolers). if u get something brand name, u will get a very efficent core which will handle alot more boost. its just how much u want to spend and ur needs..
do your remember the guys username/company?
http://cgi.ebay.com.au/NEW-720x180x8...QQcmdZViewItem
this is the guy and the cooler.
thanks weq
thanks weq
