Originally Posted by fly_vti
b16a with stock internals at 7psi does 13.6qtr mile b18c and 8 psi should to 13 flat. ]
What you smokin? 8 psi means 13 flat? Care to show me some figures and timeslips? You are talking a stock motor and a mild turbo kit right?:D
You do know that eventually the rings will give way as you are turboing a used stock n/a motor. When my motor was stock I was running 9psi (didn;t last too long), I know a couple of people running 7psi stock and the motor is running fine so try to stick to the trend if you want to play safe. Don't be like me and push it to the limit.
