ahaahaha neil kneels LOL
Lets see...Quote:
Originally Posted by z3lda
You were insinuating that at 7,000 rpm, fuel usage is more than at 1,000rpm....
This will be true if you are at a constant throttle position at both levels, but obviously, in these two different situations, power output will be vastly different.
In my very first post, I said that fuel usage was proportional to POWER OUTPUT, not RPM.
I can floor it at 1,000rpm and use more fuel than some situations at 7,000.
If you are accelerating at the same rate, then it doesn't really matter what rpm's you are using (as long as you are not in a range where torque is dropping off immensly) you will still get pretty much the same fuel economy.
:rolleyes:Quote:
i dont use a economy shift point
but i only use 10% throttle
i wouldn't shift to much earlyer then 3k-3.5k, any lower you put to much stress on your engine when going up hills ect. =D
3.5-4k is perfect.
2.5k - 3.5krpm.. just for comfortable driving, not because of saving fuel, just so i don't get slammed in my seat once vtec kicks in LOL
:thumbsup: :thumbsup: :thumbsup: me too but sometimes 5Quote:
Originally Posted by VTECACCORD
when i had the R usually about 5.
Now i got the Civic around 3.5.
i shift round 2.5K - 3K everyday.
with the occasional 'squirt' ;)
3.5k - 4k
FACT: your car will not use less fuel at 5000rpm than at 3000rpm assuming constant vacuum.Quote:
Originally Posted by string
edit: I just read post 26 and you do have the concept correctly understood.
i dun go past 4k... coz the car has too much powerrrrr... i ll just be stuck on the seat
