http://forums.clubsi.com/showflat.ph...o=&fpart=1
thanks all..
EK's have sir-ii's as well pete.. 8)Quote:
Originally Posted by Setanta
your aim is not to get the highest compression but the RIGHT compression rate to build fast car.
Build your car with the goal in mind and select the cams and choose the right compression to support it.
Dont follow everyone else compression cos is different in every set-up.
Like i mentioned before somewhere, you need to calculate both STATIC and DYNAMIC compression for your setup.
Generally most of the time we know the static one. Dynamic is hardly known to people and there is a website where you can calculate that.
yes after all the research i still have alot to go..but my questions r answered
toda cam gear
toda A
ECu
headgasket
ITR mandifold..
u can lock the thread now..
valve springs and pistons?
the stock b16a vavle springs r ok or i might have to up em with type R
but that's the list for now..
This is a very good thread !
If only everyone with Cams questions would stop by and read it we wouldnt get repeated questions.
Hondar, nice work :)
thanks mate ;)
(steals credit form hondar)
your b16 valve spring wont do good. you need to upgrade it. A type r valve springs will do for Toda A, or if you are buying as a package, no harm getting one. And ensure that valvespring installed height is stock (1.320-1.325 in. or 33.53-33.66 mm)Quote:
Originally Posted by hondar
all the best and keep us posted with any updates. cheers ;)
hm...i see..
need them both do i?
Fit ITR valve springs to your intake valves & move your existing intake valve springs to your exhaust valves...Quote:
Originally Posted by [[d a n n y
Your other option is to fit Toda springs...
Though some would tell you Spec A cams are a drop in...
Valve float will occur @ high rpm with standard valve springs fitted.
Just a though, if you do streach the budget for Toda springs,
You aught to use Spec B cams over the A's as you're doing the ECU...
This will offer you better bang for your bucks...
Trust me, the low-end torque gains will more than justify this desision.
Also, the actual cost of the pair of cams is the same... (A, B or C)
Cheers
Adrian
Also - Pm answered...
