McChook:Quote:
Originally Posted by McChook
It's not the mounts, it's the mounting points on the crossmember and chassis. They do not correspond between the SiRs and the other EFs. That is, you cannot bolt a D series motor into a SiR or a B16A into a non-SiR without using custom mounts.
I've done the measurements sitting my EF9 next to an ED6 (Aussie spec 4th gen) and second gen CRX. The EF8 and 9s are totally different beasts. Mounting points are forward of the ED6 and rex. The only possibility is cutting and shutting the mount points, but crossmembers etc will not swap across and the OEM B16A mounts wont work.
How do I know about the mounts? I had to change mine by sourcing them from Japan as nothing Honda Au had matched, not even the 3rd gen CRX or 5th gen Civic :(
