its ok Michael.
I would rather get a good 2nd hand compressor than a cheep new one. and a $50 air gun will undo the bolt like in the DIY, you may just have to hit it a few more times,
with cheep air tools, its pick of the bunch. I have seen a $50 air gun undo bolts that my snap on gun couldnt undo, but it only had that much balls for its first month of use, then went to normal cheep shit operation :) then you get leemons that wont even undo a wheel nut. all depends on the quality of the tool.
SP make a good airgun for a resonable price.
Wyn. you put the key in the keyway of the crank first, then slide on the Pulley. look to see if the key is there. then start the bolt by hand, once the key is in place with the pulley is on, its not going anywhere. do up that bolt to spec
