Originally Posted by yourfather
B18C is the JDM engine code, not B18C5.
And yeah it has 4 valves per cylinder, so that's 16 valves all up.
2 camshafts obviously, int, exhaust.
VTi-R does not redline at 9k, it redlines at 8.
It does not do 110 in 2nd gear at redline, it does about 102km/h
Fuel economy depends more on the displacement of the engine and the weight of your right foot, plus the condition of the mechanical parts in your engine rather than the type of head it has.
It is true that you can get better fuel economy from having variable valve timing. Plus, you get a flatter torque curve, which means that the engine 'pulls' more evenly across the range.
As has been said by DynoDave, TODAau and a myriad of other well respected people on this forum, Honda engines are well engineered, and can be run very reliably with boost, whether that engine is modified or stock.
From what I have heard you can run between 7-10 lbs of boost with a stock engine with a good tune.
There are a lot of people on here who seem to know how to tune, and know a lot about the hardware required.
Building your own turbo kit costs about 4-5k just for parts, if you're going to do it yourself.
Tuning is 1.5K including a standalone ECU, depending on your engine.
obviously with the engine, if you aren't acheiving good compression because of engine wear and tear, you might need to rebuild, which is when you do the forged internals thing.
