has he ran it down the 1/4 mile yet?
nah not yet
ill try get him to run it soon =)
mad shit... would be a monster
hey how long did it take him to do the conversion?
i just finish my conversion with a jdm b18c type r 98 spec full type r conversion including the 5 stud conversion on my eg 4 door vti i also used the itr radiator and aircon set up, and a toda flywheel with factory itr clutch kit and running a n1 mugen computer and 4 to 1 jdm headers and a trust exhurst .the car is awsome response and power all the way to 9000 rpm . toda valve springs and spec b cams going in this weekend.
DAMN sounds hardcore, did u take it to a shop or did u do the conversion on ur own, if so how long did it take u to do it? and wat sorta ECU u gona be using with the cams
i did it my self, the cams and valve spring im getting bel garage to do and gonna run the pfc as im gonan get the cam gears adjusted tom well took me 1 day to pull the old motor out and put the new motor in and the next day to wire up everything and started up, but every all complete took about 3 days...
so u had any runs against any cars yet?
and how did the wiring go with changin it from OBD1 to OBD2?
:) :) :) :) i got the adaptor
wat adaptor?
OBD1 connecters convert to OBD2 plugs 1 end OBD1 plugs to your harness and the other end OBD2 plugs into your computer
