Kris
your turbo sizing is fine mate, believe me.
Also the shape of that power curve raises some questions about fuelling, if you can provide a a/f v rpm graph, it would help us help you.
Kris
i think fueling is ok
i have a high flow fuel pump
Maybe i need a fuel pressure regulator
by fuelling I meant the shape of the fuel tables.
So are you going to tell us what your stock run was?Quote:
Originally Posted by ProECU
What mph did you run on the quarter mile?
PROecu can you state what the base run was or try to help out - rather than hit in with silly little comments k.
I can state it, but it's my given right to choose not to.
It's irrelevant to Kris_ issues.
I suggest you take a lesson in moderation.
Keep it on topic guys!
i dont have an AF Map
Kris,
you could always do this if you wanted more help on diagnosis.
Quote:
Originally Posted by LVNIT
I think the 'problem' is quite clear. You have only 6psi at redline :/
Look at getting a better boost controller, and make sure that ur cat still flows.
edit:
I want to also make note that this dyno is not done in shootout. Therefor it has even less relevance then before. Im guessing you are making around 120kw peak atm on that boost level.
This isnt the math that everyone is laughing at, itsQuote:
Originally Posted by string
160kW @ 4psi = 20kw / psi (10.5:1 ~80kw stock, which is generous!!)
through a 1.75" exhaust
compared to
199kw @ 9psi = 12kW / psi (11.2:1 ~90kw stock, which is generous!!)
through a 3" exhaust and a turbo which flows ~10lb min more.
my stock d-series went
120kW @ 8.5psi = 7kW / psi (9.2:1 60kW stock)
through a 2.5" exhaust and a turbo which flows less then any of the above
I guess we all need a MPH to settle this argument! ;)
Plus one has 200cc more capacity than the other. I was merely making a point :)Quote:
Originally Posted by Weq
But I do agree, 8psi and 180kw is fantastic. Personally I don't care if it's true or not, but a lot of people love to jump whenever there is a chance of something even slightly exagerated, even to make a point.
erm, since when does a stock b16 only make 80kW@wheels, and I think you are also misinformed on the CR of the said motor...Quote:
http://www.ozhonda.com/forum/showthr...light=dyno+day
Post#8
Bumpy1
Civic EM1 B16A2
Best run 96.8 kw @ 7747k rpm
308nm@ 119km/h
John ECU-MAN
97 CRX jdm ecu
Best run 95.kw @ 7769rpm
302nm@120km/h
97 CRX B16A2
John ECU-MAN audm ecu pod
Best run 95.3.kw @ 7769rpm
302nm@120km/h
97 CRX B16A2
Best run 93.3.kw @ 7769rpm
302nm@120km/h
Please don't continue posting misinformation.
Thanks
