Wouldn't run Mobil1 5w50 in a Euro with 30k km...too thick too young.
I would only use Mobil1 10w-30, which is the oil grade recommended for the Euro motor.
After changing oil at 2k, you plan to change again at 5k? I think its a bit overkill to do so...
the manual didnt state you need to change oil at 1k too....
Can you boys tell the difference in oils?
I can't.
BTW, I run full synth 15w50 in my 13:1 comp 12,000rpm dirtbike, and I can't tell the difference between 15w50 and 10w40, besides the 15w50 seems to last longer.
A 50wt oil does have more drag inside the engine than a 40wt. In terms of horsepower and fuel eco, you probably can't tell driving it.
As 90% of engine wear occurs at start-up, a 50wt, Mobil 1 5W50 will have a thicker viscosity over 100cSt than a 5W40 around 70cSt to start off with. The viscosity of 50wt is further away from the operating temperature than a 40wt, it will take a slightly longer time for 50wt to increase its lubrication ability than a 40wt. Thus, the increase of start-up wear.
Furthermore, there is no real benefit using a 50wt than a 40wt in such a car with its nearly new condition. If it is a car over 200k km mileage battling fuel dilution, then that's a different story.
will be buying a new bottle of 10w-30 or 10w-40 for my next service. :)
