would mixing different brands of oil hurt the engine
eg... i need to top up and want to add litre of oil. engine currently has feo 10w30.
will topping up with different oil stuff up the engine?
is honda feo mineral, semi synthetic, or full synthetic?
and wat about mixing different viscosity? does it matter?
Honda oils are all mineral, wouldnt recomend changing from your normal mineral oils to fully synthetic. Esp. with the H22a motors.
It's alright to change from mineral to full synthetic, AS LONG as the viscosity is the same. If the viscosity is thinner (like it is for most synthetics), then there could be problems. If you're already using FEO 10w-30, then you can change to a synthetic 10w-30 or 10w-40.
Alright if you say so, but I would never use fully synthetic on my H22a. Everyone else can.
that may make sense
because my mechanic says mobil 1 is no good for my car. he said the old formulation like around a year ago is fine, but then they changed some properties of it or something. i don't know too many details, but yeah he says its no good for our cars, and he's had some bad experiences with it.
the reason vtek brought up could be part of the problem my mech was talkn about? dunnoz. so yeah im a bit hesitant to use it, even tho its a popular oil..
I don't quite like Mobil1 as well.... Even with gold Mobil1 10w-30, which has the same viscosity as FEO, the valvetrain will sound louder for some reason.... If you are talking about the silver bottled 5w-50 Mobil1, that is not the right viscosity if you are replacing FEO.
Swapped over from mobile1 to elf full synth.. feels the same but the engine warms up quicker and oil being consumed less.
go the motul. i think its the 800 series its fully sick, um, i mean fully synth 5w40 been using it for 100,000 never missed a beat. its $55 retail 5 litre which is perfect amount for oil change, but offer them $50, they should take it! Anyone recommend good oil filters? I use Ryco's they seem ok, they're the most expensive from bigw anyway...
