I would also mention that there is a simpler way for the wiring
use a RYWIRE VTEC OBD0 Sub harness - $50 -$60 then you just splice into the existing D loom, then use the plugs (which are on the loom) to connect to the VTEC unit, Oil pressure etc..
Its alot easier than mucking around with the cabin loom from the donor car
