sounds good. also when you attached all bolts on, did you tighten it up hard while off the ground or you just hand tighten then release back to ground and then tighten all bolts?
was just thinkin if you tighten while off the ground, would this change the geometry of the sussy. maybe causing premature bush failure???
thanks
