im using dc2 front seats and ek aftermarket springs
So I cant buy EK Hatch Coil overs and install into my EG hatch is that correct because I need to change the rear lower arms but the fronts will fit correct ?
only difference is the rear control arms attachment, eye style or fork type.
ivan
fronts should bolt up
you can't switch lca's between ek's and eg's(ek's are longer than eg's) but you can modify the bushing to fit
i haven't checked the dimensions before but i suspected if you picked up a replacement bush for an ek you might be able to press it into the stock eg lca so you don't have to shave down the bush
eg6/itr are a different ballgame though being eyelet's instead of forks
im about to pick up eg king spring's super lows tomorrow morning and will be putting them on my ek hatch (using stock ek shocks). Am I going to have any trouble's?
f*** yeah
inb4 wheels scrubbing thread
thanks for informing me, was a little worried there would be a problem since eg is a fairly smaller vehicle but the only problems ive found in research is the eg / ek rear shocks dont co-opperate.
Will be crap to drive - no shock travel.
Depends on wheel and tyre combo, camber settings etc
