Originally Posted by XP02ED
oh so the ground wires are going to the ECU, so no wonder why i wouldnt of got light on it right? or wrong?
so basically all i need to do
test wires from battery to injectors if thats active.. pretty easy just the regular wire test right..wire from main relay(not battery) to injectors,turn ignition on,put multi on 12V scale,put black probe on ground,ie neg bat terminal,engine block bare metal or chassis bare metal,touch red probe to yell/blk pin inside connector,& see if u get 12V
then ill need to check the ground wires from injectors to ECU do a test on these wires using the multimeter or the same tester to see if its acive (dont quite get how ill test these wires)U need to test that the wire is unbroken,so if u get a long bit of wire,wrap it around one of the injector plug pins of the wire your testing(or get a friend to hold it on there),that way u will have one long continuous bit of wire which multi probes will be able to reach both ends of to test,well hopefully it will be continuous.Concentrate more on testing the power,yell/blk, wires ,cos if all 4 injectors arent firing,then its highly unlikely that all 4 ecu wires are broken,unless a plug has come loose at the engine shock towers or ecu.These are stock injectors we are talking about isnt it,theyve never been changed before? Ive forgotten.
i dont get what mean by "when u touch the probes to both ends of the wire(get a long piece of spare wire to join at one end to do this simply,so u can form a loop)"
im not familiar with this stuff aye!
