no doubt there would be custom ones avalible. spoon make 70mm for a starters.Quote:
Exactly, where would you find a 90mm Honda throttle body. If you have a N/A Honda in need of a 90mm throttle body, then you may as well fit ITB's :thumbsup:Quote:
I seriously doubt the factory B series inlet runners could be bored out to 45mm to make a 90mm throttle body worthwhile.
Spoon's 70mm throttle body is 70mm at the mouth. The butterfly is only 62mm. The real throttle body measurement is at the butterfly.Quote:
Originally Posted by barefootbonzai
s2000 is 65mm.
B series man.... B series.Quote:
Originally Posted by Weq
Does any1 have quad throttles on here for street use?
skunk2 make up to 70mm
i got 68mm
i did but not anymore, car wasn't quick enough, and then needed a rebuild. So i sold it.Quote:
Originally Posted by Klayemore
What itb did you run before ? what ecu?Quote:
Originally Posted by Limbo
hm...with ITB is not quick, hmm...mind telling me what sort of power you are pulling?
ITB was stock, they run stock ITB on the 20v corollas, was imported of course. Ran a wolf 3d. v3.11 (it was a while ago), made 95kw at the wheels. Got an old dyno sheet somewhere
What i did was open up each on so that you could run a small pod ontop of each throttle. Sounded great though.
:thumbsup:Quote:
Originally Posted by CUL8R
