Off all the time. But you have to get used to using your accelerator more and not just keep it at one position through the corner.
Ok, will look into it when it's time for tyre replacement,Quote:
Get better tyres. Bridgestone RE001 adrenalins are pretty reasonably priced
mean time I'll just be more gentle with the gas :) ... Thanks
this may happen.
http://www.youtube.com/watch?v=0tZlCx9VYkI
my front and back tyres are equally good ...almost like newQuote:
How are the condition of your tires, the front vs the back tires?
Accord Euro has only front 2 wheel sensors, this was back in 2004. They might have put 4 wheel sensors in 2006, but I have no idea if they did or not.
Yea, i had to test the limitations of my cd5.
I test it before i do any modifications which could influence the cars movement.
e.g. I tested it before changing my stock suspension to tein coilovers, the difference is brilliant haha. The car had a bit of body roll, but far easier to handle than stock suspension.
i also tested before replacing my brake pads, I went round the corner, and tried to see if i could get the car to slide out a little before and after i changed the pads (without locking up abs). It was in an industrial area, in the early hours. I do not endorse this activity at all, however I do feel people should know the limitations of their car, it will help you when driving in shitty conditions. I have friends with corollas who think wet roads have no affect on them turning corners and hitting the accelerator as much as they can.
I know ppl will get on here and start abusing me for trying this on the roads, but it was in a good area, far from any cars or people.
Have done this but in a turn at about 60ks,
Understeered a touch and traction control kicked up but apart from that your drivetrain or chassis will not experience problems later on for a menuver like that
