Cool, that's pretty easy to do. Thanks!
Negative terminal pull out waiting time = 10-15 mins.....
hmm what if i pull off the positive one??? :P
the electrons move from the negative to the positive, so maybe the negative is a better choice hehe
i dunno how it makes a difference really.....
Sorry to revive an old thread, but what does resetting the ECU actually achieve?
would it be a good idea if ur the new owner of a 2nd hand car?
Re-reviving an old thread...
But the reason to take off the negative is that if the tool you are using (spanner) touches the body as you do up or remove the negative it doesnt matter.
If you put on the negative and then as you do the positive you touch the spanner to the car you will blow a chunk out of the car at best, or burn the whole show to the ground, at worst.
So when swapping the battery out-
remove negative
remove positive
remove battery
replace battery
replace positive
replace negative
