Make sure you take your pressure readings after a bit of a drive.
At first my car will idle with 45 PSI of pressure (cause its still warming up and the oil is thick) but once i go for a drive and the oil thins out i end up with about 25 PSI Oil pressure. I tend to hit max oil pressure pretty early (75 PSI @ 3500 RPM which holds steady through to red line, even throughout the vtec engagement.)
after i bit drive i got 36psi first start i got 72.5psi and WOT i got 80-90psi it seems to be high enough for the oil pressure compare to the B engine but just dont know what will be pressure from the f20c hopefully they are all the same
thx jason
