Actually the non-vtec pumps "flow" more per revolution than the vtec pumps, not the other way around.
for b18c ... as long as u use a 22 tooth water pump its fine ..
should say 22T somewhere on it..
should try a lower temp thermo switch and lower temp themostat since ur turbo
it was the radiator suking in too much hot air.
it placed full size radiator bak...
take out the thermostat and drive around for comparison sake, if it solves your problem, then try get a lower temp thermo, or just leave it out, since the heat from the turbo will be heating up the radiator fast enough.
i patched up the full size radiator temp stays at high 80s.
but i will take the therm out this weekend as ive got no time during the week
Hey mate have you had any progress yet
my car is basically set up the same as yours and is doing the same thing.
If you have fixed could you post it up to help me out please
thanks
