h2d kits are also avaliable if u want to retain ur dseires box
What the hell?
Why would you change the gear box? Get a mount set from JDM yard. Hasport mounts are designed to bolt the h22a with box into the EK. And heavy front???? let say 50 kg. Change your bonet to fiberglass or CF, change your battery to light weight, loose the air con, there're 25 k+ already. And for the wiring HAsport also sold harness conversion so u can order that through JDM yard im sure. Im doing this atm but it is hard to find a good half cut (well for me anyway). Talk to some one that done this or a tune shop dont listen to e-machanics. hope that help
