Thanks Hisoka!
Thanks Hisoka!
Looks good!
once you polish it, is it a good idea to put a clear coat over it so you dont have to polish it often?
I tried doing mine with the sand paper as I had a few scratches on the lens. Didnt work out too good. Lens ended up really foggy...even with using the finest grit sandpaper at then end then polishing. Reckon i could buy the autosol and it will clear it up? Any idea if you can buy headlight lens' by themself??
did you wet sand it? wet sanding is important as it will smooth out the lights, rather then dry sand paper, start from rough then move to fine. Then using a polishing clothing, apply about 10cent coin amount on the cloth, spread it over the lights, next thing you would do is keep rubbing the cloth hard, you will eventually melt rough layer away. Remember to change to a clean part of the towel and rub hard, until you see a clear coat shine through.
btw it'll dull up after you wet sand it, it doesn't matter, as long as the lens is clear, you can then apply polish and start polishing it
yeah did exactly that, might go get some more wet sand paper and use a finer grit. used autosol but not much luck.
what product should I use for the clear coat?
here's the difference when i first got my car, you can really tell the difference from the left side
http://i129.photobucket.com/albums/p...3/DSC00106.jpg
I use autoglym paint renovator, works like a charm.
