i will get all my fuses(power, amp and h/u) changed even though they look perfectly fine.
Try jumping a wire from the + on the amp to the remote. If everything turns on then there is something wrong with your remote wire or your headunit.
Check the voltage of the remote wire under load. It might not be getting enough power to the amp.
If infact your remote wire is not giving enough current. You have 2 options.
1. Connect the remote wire to the ignition.
2. Run a relay.
yes if your amps turn on. Its your remote wire causing your problems.
I bet it's a dodgey earth.
i had the exact same problem,
i did all the check ups:
1 - All 3 ground cables
2 - power
3 - remote
4 - RCA leads
5 - fuzee
i just ended up rewiring with 4guage wires; worked a treat.
