How do they compare with the Spoon one?
heat will expand your hose lines therefore reducing brake pressure .... thats why you get braided lines to reduce expansion and maintain brake pressure, hence less brake fade....
thats why i thought brake pads and braided lines are the first thing to address.
correct me if im wrong, but aftermarkets calipers only give you more consistency in pushing the pads to the rotors? but then again the type r calipers are good already. what other advantages are there?
larger calipers also = larger clamping surface area = better braking
i guess so .... but does that mean bigger and more expensive pads?
um...in all honesty, unless you are doing frequent track events, upgrading larger brake calipers is all for show.
you'll rarely use the full extent of the brake system on the road anyway, unless you're doing something pretty stupid on the road.
brake fade = (quoted from wikipedia):thumbsup:
The reduction of friction termed brake fade is caused when the temperature reaches the "kneepoint" on the temperature-friction curve. [All brake lining is cured under mechanical pressure following a heating & cooling curve, heating the friction material up to 450°F to "cure" (cross-link) the phenolic resin thermoset polymers: There is no melting of the binding resins, because phenolic resins are thermoset, not thermoplastic] In this form of fade, the brake pedal feels firm but there is reduced stopping ability. Fade can also be caused by the brake fluid boiling, with attendant release of compressible gases. In this type of fade, the brake pedal feels "spongy". This condition is worsened when there are contaminants in the fluid, such as water, which most types of brake fluids are prone to absorbing to varying degrees. For this reason brake fluid replacement is standard maintenance.
http://www.ozhonda.com/forum/showthread.php?t=70142
DIRT CHEAP for anyone considering SPOON over BREMBO =)
Offers welcome.
