yes EK1 gli has a 22mm front stock swaybar and direct bolt off and bolt on with the 26mm front swaybar. its exactly the same, the only diff is just the thickness of the swaybar.
sorry to bump an old thread.
anyone know if i need ek9 front lca's for an ej8?
no you dont need ek9 front lca's because your ej8 came with a factory front swaybar therefore it has the mounting holes already
cool, thanks for that.
u cant just drill it. the holes are on a mounting bracket that is welded to the control arm. if u kno wat ur doing u could easily make it though
am i missin anythink, can anyone confirm this? ill like to know befor i start putting eveythink in and dont wanna realize im missing somfink mid way into it.
[img=http://img37.imageshack.us/img37/7150/dscf1603i.jpg]
[img=http://img37.imageshack.us/img37/8384/dscf1605a.jpg]
[img=http://img37.imageshack.us/img37/5449/dscf1606s.jpg]
u dont need that subframe setup. from wat i can see ur jsut missing the d brackets for the swaybar bushes, and the 4 bolts to attach it all up the the chassis. other than that u have the swaybar, lca, endlinks and bushes. it might be a good idea to get nyloc nuts for the endlinks, just to make sure they wil never fall off.
