But more negative camber on the rear and zero camber on the front = more grip on the rear than the front when cornering hard = understeer.
Nope it was from ebay. This seller: http://cgi.ebay.com/ebaymotors/03-HO...spagenameZWD2V
sortof, but its basicly the suspension following an arc at a set radius. the suspensions travel starts at 90deg which is parralel to ground, then progresses to 45deg which is full suspension compression, also resulting in alot of camber. its pretty simple lots of pic's on the net. check out wiki
cant belive people were complaining about 3deg! i had -8deg on the rear... now i have -1.5 :p
ingalls ftw
i have just bought an ingalls camber kit for my 04 euro.. does anyone have a DIY write up on how to install these, or can anyone recommend a place in melb (south east area) that can install it for me ???
any alignment place will get them installed and aligned normally, but just need to call around. Peddars might or your general workshops.
Bob jane etc won't do it cause they refused to even align my car.
was a while ago i called around i think it was haberfield.
Beaurepaires also refused me too.
how much did the lower and camper cost all together and how much drop??
i click on the link but cant locate the item
are we talking about this item?
http://cgi.ebay.com/ebaymotors/_Car-...3A1|240%3A1318
Cheers
lower? no lower.... lowering of the car myself is free, but install was mates rates for tein monoflex coilovers.
camber was installed by my mate, included in a few things i got done,
Alignment depending where you go should be around $60-110
My ingalls camberkit was picked up for $250 or so late 2007 so was cheap.
