Originally Posted by
ewendc2r
I will let you know how it goes -- Essentially I will be relocating the Oil Pump, and getting rid of AC more than likely (because it doesn't work at the moment due to a **** up I made and I just deal with it, we have windows!). Putting the Rotrex where the Oil Pump is, short piped intercooler setup and 10psi should be good for around 280whp with max boost around 3500rpm -- This is fine as the B series is a high revving motor and if you want that power how often do you put the foot down in that gear or really, do you down shift? My biggest advantage other than added straight line speed, is the ability to short shift for more corners wihout worrying about dropping out of the power range.
Also looking at 16"x7.5" wheels ... you get the idea
