Haha......wake up luke,
Maybe thats whats happening to your 60 footers as well,half asleep?
Yeah,put a voltmeter across your map terminals at the ecu(put it on peak hold if its got that), go out hit full boost,see if its reading >5V.If so your pushing outside the boundaries of the stock map.
Its commonly known fact as well,that u know your pushing its boundaries anyway at 11 psi
Seriously man, do u listen. Do u know what a colder plug does?
Your car is heating up at the strip, the plugs are going out of there heat range and bang, u are loosing spark. It feels like a rev limiter. You cool the engine back down again, they come back into the heat range, and bam, you got spark again.
*smacks head*
I have NEVER EVER heard of a OEM pump going. My stock pump flowed just as good as it ever did, 15years old. But hey, its your choice to throw money away.
Thats what I really meant. Not boost cut as such, but outside the stock map sensor range.
What does it do? Are you accelerating and then sudenly everything cuts out silent? You back off and things start running again? If so your maxing out the map sensor.
