Protek has one that is at 176kws, i dont know much about it though.
Woah, farout....... are you sure? NA????? If it is, then a new benchmark has been set. 176kw atw?..... woah........ :confused:
Best DC2R STD engine with a few mods I have tuned
Toda Spec-B cams
Toda Cam Gears
Toda Valve Springs
Toda Header
Exhaust I cannot remember I think 2.5" ??????
Programmable ECU
Mugen intake
Hondata intake gasket
Cometic head gasket
A STD DC2R on our dyno will make between 98-104kw ATW
this car made made 126kw which I was very impressed with, I have tuned other B18C based engines that make alot more than that. And the most I have seen is 147kw so I hope this helps.
Regards Dyno Dave
Dave the exhaust was 60.5mm ;)
Thanks dave, are you the guy that tune hondata? Nice to meet you mate...... so you reckon the one by protek thats giving out 176 kw is turbo? :confused:
no its definately NA, I was watching it on the dyno, no big swooshing turbo, no bov, no cooler, no nos. All motor.
Im not sure how that dyno reads tho
http://www.dynowars.com.au/dynoResults.htm
scroll down to 4cyl NA
stock DC2R ran 160hp/120Kw @ the wheels
Hey how do you know its stock????? thats quite high for a stock dc2r........ :thumbsup:
176kw seems a bit far out to me....
120kw atfw stock is FAR OUT.... i want that car out of the factory hmmm...
in other words, the dyno was reading quite a bit over in the power deparment.. ie 176kw would be more like 150~kwQuote:
Originally Posted by type one
The NA DC2R with the most power I know of, is the person I am quoting.... I believe.Quote:
Originally Posted by blackdc2
176fwkw - Lemme guess - Croydon?? Sorry, perth - SST???
Whatever
