ok, dam i did wrong , i just mounted the flywheel with out doing criss cross pattern well i did but didn't have clue
and amm , so the flywheel cover the black thing , does that slip in before doing up the flywheel or after ?
the fly wheel cover goes on after you've bolted the gearbox back on. one of the last few things that goes on.
along with all the brackets and wiring loom.
ok cool cheers
and now god im embarced to ask this
but i bought a super cheap auto brand clutch aligning tool , got instructions on the back but i dont quite 110% under stand it , any advice
once the fly wheel is on you put the tool into the center where the pilot bearing goes. (the hole)
then you slip the fricion disc over it to center it on the fly wheel. then you put the pressure plate over the top of the friction disc and line its holes up on the flywheel.
as you tighten the pressure plate (in the way i described before) you need to keep jiggling the alignment tool and making sure the friction disk isn't stopping it from coming out.
the tool needs to slide in and out smoothly as its exactly what the input shaft on the gear box has to do (an alignment tool can be made from the input shaft out of interest)
make sure you go around the pressure plate a few times, you will find that once you do your pattern once the bolts that you thought were tight will feel looser. just keep on going around the pattern until they're all done up firmly.
emergency help me i got tough people at my house helping
they need to know
how do u install the flywheel cover, we have slipped in the gear box alrady but onmly by 2 bolts so what to do help pelase
do we even need the plate
props to u sir, cant change a tire then straight into a clutch change. Thats the only thing that i cbf doin on my car
did it , my mates "figured" it out , we put it before the flywheel went in
and as the gear box went on the same bolts closed the flywheel wheel
sigh im stuck
the motor wont start it flashes starter motor , so ya i need to know where the plugs go to the starter motor again , silly me should know but ya
ooo shit the motor wont start lol nows a good time to call a mechanic lol
haha no worries. he's got it going now.
after a few phone calls to me its all fixed :p
