50psi on 10% tread? ur kidding right lol. no traction even in reverse
Mr. Darwin, where are you?
lol shurrup everybodyy..i put hi psi 4dlulz
For the what?
Anybet you won't be telling us to shttup once your tyres pop, when you pull a burnout, and you break those rims.
I disagree.
The tyre deforms under load. Causing it to roll.
A higher PSI prevents this by making the sidewalls stiffer.
In a car thats FF focused; a higher PSI at the front is crucial for cornering.
Thats why Honda have it like that from factory.
However if you run aftermarket sussy & your own setup different story...
In relation to PSI GSI; 50PSI I can understand as a misunderstanding. Inexperience if you will.
To put re-treads though I can not.... Still baffles me as to why someone would do it to an integra...
Semi-trailer maybe...
