Originally Posted by Civic Type R
OK Project complete :)
Test results :
Ignition timing was 3-4degrees out.
fuel was too lean and now it fine with the installment of a 450HP Walbro fuel pump.
fuel is a tad rich at idle - low rpm -12-12.5 but at peak rpm its around 13.7.
Injectors are fine.
Mugen ECU is fine
Fuel pressure is fine and the rest is A ok :)
yay !
I know i had originally stated engine to be at 240HP but it was confirmed to be around the 215HP mark. = 160kw
a bit better than the 118kw in there originally :)
