Yeah still driveable, but not recommended..
I found the clunking noise disappeared when I changed my rotors and pads.
Nah the clunking noise is coming from the steering rack I'm pretty certain about that cause when I turn the steering wheel I hear it and feel it through the column
I did it like 2000km ago.... Im guessing its the slider that has worn out, if Im correct my understanding is that the slider is made out of some plastic. If thats the case it was an unwise material to choose by Honda engineers.
Does anyone else feel that even though the ep3 is well built it just doesnt have that proper JDM built feel to it?
Better change ur username lol
when i got my steering rack regreased.. there was still a little bit of creaking when i take off... only like 1 or 2 small creaks.. which is alot better than previous
but i do notice sometimes it comes back and it creaks back to previously but after a while it just goes away...
http://i1079.photobucket.com/albums/...6/IMG_0575.jpg[/QUOTE]
Sorry dont mean to hijack thread but what did you replace it with. Mine is starting to crack as well. Did you replace with the same hose or a plastic one?
http://imageshack.us/photo/my-images...mag0056hy.jpg/
http://imageshack.us/photo/my-images...mag0056hy.jpg/[/QUOTE]
Replaced it with another OEM hose. They eventually crack though, so better off getting a silicon one such as Tegiwa.
Yeah I just went with the Tegiwa one.
Btw I have now seem to have sorted out the high fuel consumption. I replaced the spark plugs with ones that are actually rated for the K20A. The ones I had previously were denso ones and were for the civic si got them off amazon thinking they would also suit the JDM k20 down to 10ltr/100 and that was halfway through a tank so hoping that with the new O2 sensor that goes lower.
Another update, have installed the rear coilovers and whiteline swaybar. Will be getting the fronts put in next week along with the j's racing tie rods, j's roll cecntre adjusters and if I have time the whole energy suspension bushing kit as well.
Rear on the car feels nice and planted now.
Will have some pics sometime next week.
which sparkies did you get mate?
Same as Rps got in his thread the NGK BKR6EIX ones
Is there a big difference between Tegiwa and ebay ones. Shipping to Aus is 50 pounds.
are you buying from official tegiwa site?
Yep....
Cracked Intake pipe looks ****ing nasty!
Roughly How many Ks before they crack?
What options are there for a replacement? Tegiwa and Js Racing only?
Ok finally some updates!
Got my Buddy Club coils in on all corners at last.
Will let the fronts settle a bit for a week and see if they drop anymore. Currently have a little less than a two finger gap, or two tight fingers basically, might look at another 1cm drop all round.
Before
http://i1250.photobucket.com/albums/...513_133522.jpg
After
http://i1250.photobucket.com/albums/...724_213427.jpg
Yep, needs more low I think.
Before when I put the rears in I had some huge camber angle.
http://i1250.photobucket.com/albums/...724_122947.jpg
http://i1250.photobucket.com/albums/...724_123014.jpg
J's racing tie rods and custom steering bracket installed also.
http://i1250.photobucket.com/albums/...724_164926.jpg
http://i1250.photobucket.com/albums/...724_164842.jpg
Also go the front lower control arm bushings installed at the same time.
One of the apprentices there was changing my wiper blades, got home an hour later from clayton to northern suburbs only to realise my left windscreen wiper blade is missing.
Now I need a new alignment. I am getting some scrub when I turn left none on the right assume its due to camber etc being all out of wack.
Anyone know where I can get one for cheap? I'm assuming I will be making another 65km round trip to Clayton again to pick up my wiper blade....
Nice :thumbsup::thumbsup::thumbsup: Good to see you got all your stuff in.
Did you end up going to the place that I referred you too? How was the price??? Coz I'm looking at going there to get my clutch installed.
For wheel alignments, if you want cheap ones. Try Jax Quickfit in Caulfield, from memory it is $44 or $48 for a full alignment. Tell them you're a member of nissansilvia.com for that price or tell them Michael referred you. Just don't let them touch your brake fluids :p
Yeah I ended up going to aj. The price was good considering that I got quoted that price elsewhere just for the tie rods and I got alot of stuff done with him yesterday.
I would say go there to get your clutch done, he doesnt charge by the hour just by the job which is great.
I'll go and give Jax a visit for a wheel alignment today or tomorrow.
Btw does anyone know where to get EP3 wipers? Or is it a particular type?
Good to hear man! Cool, I'll most likely get it done there. Had my clutch installed there for my 180 ages ago. Pretty cheap labour and he got it done within a day. I couldn't remember exactly how much i paid. Called him just before and got quoted $500 to install the clutch kit on the EP, damn cheap compared to other places wanting 800-900! He doesn't have a loan car unfortunately, which could prove to be a bit tricky.
Woah! They're dirt cheap!
+1 for the aero style clip on ones. They wipe a lot smoother and cleaner than the OEM metal ones with the normal inserts. Plus they are a breeze to install, no cutting/measuring required.
Damm they are cheap, just one at supercrap is $35. Thanks for that man :thumbsup:
Yeah thats a good price for the install of a clutch as its a pretty big job, plus you know with him he will just charge you what he quotes. Any other place and they will go by the hour, so any misshaps or phuck ups on their side cost you money.
Also went out today and dropped the front another 10 mill Im thinking the ride height looks sweet now.
Opinions?
http://i1250.photobucket.com/albums/...725_163721.jpg
Does the steering bracket and tie rod ends really improve the handling or geometry? I'm dropped a little less than a finger gap up front, similar to your height, and been using stock bracket and tie rod for ages. I keep coming back to wondering if I really need it...
I dont know about handling but I would say that it does improve geometry as it brings the tie rods higher and reduces the v angle you get from lowering it. So by having the angle close to stock it will reduce bump steer so it would play a role in handling.
Open up your hood and take a look at the tie rods, if they are angled up its probably good at looking at getting the bracket or the roll centre adjusters to correct the problem. I think that one or the other will suffice tbh. I didnt take a look at my rod angles today after the drop but I'll see if I can get some pics tomorrow.
buy an intake hose yet? check this one out. http://www.ebay.com.au/itm/SFS-Silic...item25719dac4e
Thanks for the offer man but im in melbourne. I needed to get the left wiper asap as i didnt have one and melb and rhe rain...
Btw did anyone have any issues with getting their camber settings sorted?
Guy is telling me I had -5 camber on the rear but he is telling me Its hard to get .5 on the rear done wtf?
Without camber arms your getting -5 no way!!!!
looking pretty rad man :)
Clear you inbox please :p
Cleared!
Finally got my Titanium exhaust after waiting ages for it, will try to have it installed very soon its very very light.
http://i1250.photobucket.com/albums/...807_212612.jpg
Also got these today.
http://i1250.photobucket.com/albums/...807_212959.jpg
That exhaust looks fantastic. Almost a shame that it goes under the car and not on the roof!
Is that a BYP item? Keen to hear your thoughts once its on, I have been eyeing one of those myself.
Yeah looks awesome but we dont need ricers with cannons on their roofs :p
Yeah its the BYP stuff, originally I wanted to get this back in May or so and waited forever when I understood this to be available straight away at a certain price. Then waited another 4 or 5 weeks for it to be modified from DC5 to Ep3. So a word of warning you can get some frustration from this, but its possible now that he has the dimensions, this wont be an issue anymore.
I'll definitely post up some thoughts on the exhaust and try to take some video as well.
similar to my j's racing setup. But I have the dolphin fin tip
Ok So some small updates.
Got my headers and Ti exhaust installed over the weekend and the difference is amazing.
The car pulls from down low much better now and then just screams into vtec and the sound is incredible.
Also had my track day at sandown yesterday. I had a couple of offs into the first corner on practice one and then 1st sprint as I came in too hot into that corner, second time I went off I hit the ripple strip pretty badly and unfortunately hit my mid pipe on my exhaust and dinted it :(
After those two offs I had a pretty good day learning the track and the limits of the ep3. I did easily hit the limiter down the back and front straights and that does freak you out as you have no power going to the wheels when going over the crest at the back or going over some bumps.
Here are my times for the day.
Session one:
Alfa Romeo Club of Australia Sandown Sprints
SANDOWN INTERNATIONAL MOTOR RACEWAY
AROCA - Sprint 4
Practice S4 10 Mins
Scheduled Start 00:04
Page 1 Issue 1
Start Sun Aug 19 09:49
Elapsed Time 10:00
__________________________________________________ __________________________________________________ ____________________________
Pos Car Competitor/Team Driver Vehicle Cap CL Laps Fastest...Lap Gap
1 231 AROCA Jeremy EDWARDS (4) Alfetta GTV R3 5 3 1:35.9027*
2 699 AROCA Frank MAXWELL (4) Subaru WRX A2 6 6 1:37.1058 0:01.2031
3 32 AROCA Hamish DALTON (4) VW R32 A2 5 4 1:43.6654 0:07.7627
4 130 AROCA Tony RADITSIS (4) Alfa Guilia Super R3 6 6 1:44.4288 0:08.5261
5 268 Jake BEKKERS (4) HQ HOLDEN A2 6 2 1:46.2287 0:10.3260
6 45 SAU-Vic Francesco SGRO (4) Nissan 200 SX A2 5 3 1:46.4884 0:10.5857
7 777 AROCA Paul KLISARIS (4) Alfetta GTV R3 5 5 1:46.5861 0:10.6834
8 22 AROCA James GRAY (4) BMW 318i A1 5 4 1:46.6255 0:10.7228
9 48 Cerberus Stephan GRONDIN (4) Nissan Skyline A2 6 2 1:47.1209 0:11.2182
10 4 AROCA Vince SARTOR (4) Alfa Guilia Super M3 2 2 1:47.7907 0:11.8880
11 19 AROCA Dominique CHALEYER (4) Alfa Giulia Sprint M3 5 4 1:48.1744 0:12.2717
12 139 PCCV Reg POLSON (3) Peugeot 205 GTI A1 6 6 1:48.2509 0:12.3482
13 511 AROCA Phil AARONS (4) Alfetta GTV TS R3 5 5 1:48.7877 0:12.8850
14 16 AROCA Michael SALVATORE (4) Alfa 155 Q4 R5 5 5 1:49.7327 0:13.8300
15 33 AROCA Paul CHALEYER (4) Alfa Giulietta 750 S M3 5 5 1:50.3816 0:14.4789
16 302 MX5 Vic Graham WILSON (4) Mazda 121 A1 5 5 1:50.4003 0:14.4976
17 18 AROCA Richard OUTRAM (4) Alfetta 1.8L M3 4 4 1:50.9853 0:15.0826
18 5 AROCA Gabriel DIGENIS (4) Alfa 105 GTV M3 5 4 1:53.4594 0:17.5567
19 41 VHRR Michael BAN (4) Sunbeam Alpine A1 5 5 1:53.9037 0:18.0010
20 44 AROCA Spaniard EP3 (4) Honda Civic A1 2 2 1:55.6435 0:19.7408
21 117 AROCA Bruce JACOBS (4) Alfa 75 TS M3 5 3 1:57.4673 0:21.5646
22 3 AROCA Neil CHOI (2) Alfetta GTV GpS R3 4 4 2:00.5049 0:24.6022
23 47 AROCA Oriano RIZIO (4) Alfa 105 GTV M3 4 4 2:02.4094 0:26.5067
24 9 AROCA Tim SHANNON (4) Alfetta GTV GpS R3 4 4 2:02.5252 0:26.6225
39 AROCA Matthew FRANCIS (4) Alfa 90 3L M4
Fastest Lap Av.Speed Is 116kph
R=under lap record by greatest margin, r=under lap record, *=fastest lap time
Session 2
Practice S8 15 Mins
Scheduled Start 00:08
Page 1 Issue 1
Start Sun Aug 19 11:24
Elapsed Time 14:59
1 231 AROCA Jeremy EDWARDS (4) Alfetta GTV R3 9 6 1:33.3500*
2 699 AROCA Frank MAXWELL (4) Subaru WRX A2 9 7 1:33.7778 0:00.4278
3 16 AROCA Michael SALVATORE (4) Alfa 155 Q4 R5 8 8 1:37.9377 0:04.5877
4 7 AROCA Robert VODOPIC (4) Nissan Pulsar A1 9 8 1:38.5961 0:05.2461
5 48 Cerberus Stephan GRONDIN (4) Nissan Skyline A2 8 6 1:38.9541 0:05.6041
6 45 SAU-Vic Francesco SGRO (4) Nissan 200 SX A2 8 7 1:39.2713 0:05.9213
7 130 AROCA Tony RADITSIS (4) Alfa Guilia Super R3 8 7 1:39.9362 0:06.5862
8 19 AROCA Dominique CHALEYER (4) Alfa Giulia Sprint M3 9 7 1:40.9905 0:07.6405
9 777 AROCA Paul KLISARIS (4) Alfetta GTV R3 8 7 1:41.2698 0:07.9198
10 511 AROCA Phil AARONS (4) Alfetta GTV TS R3 8 8 1:44.3603 0:11.0103
11 32 AROCA Hamish DALTON (4) VW R32 A2 8 8 1:45.4384 0:12.0884
12 5 AROCA Gabriel DIGENIS (4) Alfa 105 GTV M3 8 8 1:46.0126 0:12.6626
13 44 AROCA Spaniard EP3 (4) Honda Civic A1 2 2 1:46.0653 0:12.7153
14 268 Jake BEKKERS (4) HQ HOLDEN A2 8 8 1:46.0907 0:12.7407
15 18 AROCA Richard OUTRAM (4) Alfetta 1.8L M3 9 8 1:46.2858 0:12.9358
16 139 PCCV Reg POLSON (3) Peugeot 205 GTI A1 8 6 1:46.5578 0:13.2078
17 302 MX5 Vic Graham WILSON (4) Mazda 121 A1 8 7 1:47.1303 0:13.7803
18 22 AROCA James GRAY (4) BMW 318i A1 8 8 1:47.8515 0:14.5015
19 117 AROCA Bruce JACOBS (4) Alfa 75 TS M3 8 8 1:48.2254 0:14.8754
20 9 AROCA Tim SHANNON (4) Alfetta GTV GpS R3 8 7 1:48.7871 0:15.4371
21 33 AROCA Paul CHALEYER (4) Alfa Giulietta 750 S M3 8 7 1:50.0352 0:16.6852
22 41 VHRR Michael BAN (4) Sunbeam Alpine A1 8 8 1:51.1379 0:17.7879
23 47 AROCA Oriano RIZIO (4) Alfa 105 GTV M3 7 6 1:51.3414 0:17.9914
24 135 AROCA Nicholas GRIGG (3) Mazda MX5 A1 7 7 1:53.3884 0:20.0384
Fastest Lap Av.Speed Is 120kph
Session 3
Practice S12 15 Mins
Scheduled Start 00:12
Page 1 Issue 1
Start Sun Aug 19 13:12
Elapsed Time 15:00
1 699 AROCA Frank MAXWELL (4) Subaru WRX A2 9 9 1:31.8047*
2 16 AROCA Michael SALVATORE (4) Alfa 155 Q4 R5 9 8 1:33.2467 0:01.4420
3 45 SAU-Vic Francesco SGRO (4) Nissan 200 SX A2 9 5 1:36.7914 0:04.9867
4 7 AROCA Robert VODOPIC (4) Nissan Pulsar A1 9 9 1:38.4841 0:06.6794
5 32 AROCA Hamish DALTON (4) VW R32 A2 9 8 1:39.5202 0:07.7155
6 19 AROCA Dominique CHALEYER (4) Alfa Giulia Sprint M3 9 6 1:40.4149 0:08.6102
7 130 AROCA Tony RADITSIS (4) Alfa Guilia Super R3 9 9 1:40.4249 0:08.6202
8 777 AROCA Paul KLISARIS (4) Alfetta GTV R3 9 8 1:40.7478 0:08.9431
9 511 AROCA Phil AARONS (4) Alfetta GTV TS R3 8 7 1:41.6898 0:09.8851
10 78 AROCA Andrew HARVEY (4) Toyota Corolla A1 8 7 1:42.0336 0:10.2289
11 44 AROCA Spaniard EP3 (4) Honda Civic A1 8 8 1:42.9142 0:11.1095
12 268 Jake BEKKERS (4) HQ HOLDEN A2 7 5 1:43.0746 0:11.2699
13 5 AROCA Gabriel DIGENIS (4) Alfa 105 GTV M3 6 6 1:43.2322 0:11.4275
14 22 AROCA James GRAY (4) BMW 318i A1 8 7 1:43.8569 0:12.0522
15 139 PCCV Reg POLSON (3) Peugeot 205 GTI A1 9 5 1:44.5787 0:12.7740
16 9 AROCA Tim SHANNON (4) Alfetta GTV GpS R3 9 7 1:45.2346 0:13.4299
17 302 MX5 Vic Graham WILSON (4) Mazda 121 A1 8 8 1:45.4801 0:13.6754
18 18 AROCA Richard OUTRAM (4) Alfetta 1.8L M3 8 8 1:45.6679 0:13.8632
19 117 AROCA Bruce JACOBS (4) Alfa 75 TS M3 8 6 1:48.3741 0:16.5694
20 135 AROCA Nicholas GRIGG (3) Mazda MX5 A1 8 8 1:48.8472 0:17.0425
21 47 AROCA Oriano RIZIO (4) Alfa 105 GTV M3 8 7 1:49.4993 0:17.6946
22 33 AROCA Paul CHALEYER (4) Alfa Giulietta 750 S M3 6 4 1:50.4253 0:18.6206
23 41 VHRR Michael BAN (4) Sunbeam Alpine A1 8 8 1:50.7497 0:18.9450
24 124 HSCCV Daniel van STOKROM (1) Holden LJ Torana A2 1 1 2:09.1682 0:37.3635
Fastest Lap Av.Speed Is 122kph
Session 4
Practice S16 15 Mins
Scheduled Start 00:16
Page 1 Issue 1
Start Sun Aug 19 14:56
Elapsed Time 15:00
1 699 AROCA Frank MAXWELL (4) Subaru WRX A2 10 8 1:32.8009*
2 45 SAU-Vic Francesco SGRO (4) Nissan 200 SX A2 9 8 1:36.2845 0:03.4836
3 44 AROCA Spaniard EP3 (4) Honda Civic A1 9 6 1:37.1865 0:04.3856 Fastest lap of the day
4 17 AROCA Justin JACOBS (2) Alfa 75 TS M3 9 9 1:37.2205 0:04.4196
5 7 AROCA Robert VODOPIC (4) Nissan Pulsar A1 9 6 1:37.9163 0:05.1154
6 32 AROCA Hamish DALTON (4) VW R32 A2 9 7 1:39.8504 0:07.0495
7 511 AROCA Phil AARONS (4) Alfetta GTV TS R3 8 8 1:40.4854 0:07.6845
8 268 Jake BEKKERS (4) HQ HOLDEN A2 8 7 1:41.2324 0:08.4315
9 19 AROCA Dominique CHALEYER (4) Alfa Giulia Sprint M3 9 5 1:41.7570 0:08.9561
10 777 AROCA Paul KLISARIS (4) Alfetta GTV R3 8 5 1:41.8977 0:09.0968
11 130 AROCA Tony RADITSIS (4) Alfa Guilia Super R3 9 6 1:42.6283 0:09.8274
12 139 PCCV Reg POLSON (3) Peugeot 205 GTI A1 8 8 1:43.3682 0:10.5673
13 78 AROCA Andrew HARVEY (4) Toyota Corolla A1 8 6 1:43.8648 0:11.0639
14 302 MX5 Vic Graham WILSON (4) Mazda 121 A1 8 8 1:45.1039 0:12.3030
15 47 AROCA Oriano RIZIO (4) Alfa 105 GTV M3 8 7 1:45.5740 0:12.7731
16 18 AROCA Richard OUTRAM (4) Alfetta 1.8L M3 9 6 1:46.3008 0:13.4999
17 135 AROCA Nicholas GRIGG (3) Mazda MX5 A1 8 8 1:47.0181 0:14.2172
18 41 VHRR Michael BAN (4) Sunbeam Alpine A1 8 8 1:50.6835 0:17.8826
19 4 AROCA Vince SARTOR (4) Alfa Guilia Super M3 1 1 6:41.5651 5:08.7642
Session 4
Practice S20 15 Mins
Scheduled Start 00:20
Page 1 Issue 1
Start Sun Aug 19 16:37
Elapsed Time 14:46
1 184 MX5 Vic Robert HART (1) Mazda MX5 A1 9 5 1:32.7697*
2 88 MX5 Vic Randy STAGNO-NAVARRA 1 Mazda MX5 A1 9 8 1:32.9932 0:00.2235
3 27 MX5 Vic Colin DENMAN-JONES (1) Mazda MX5 A1 5 5 1:33.6842 0:00.9145
4 15 MX5 Vic Stephen DOWNES (3) Mazda MX5 A1 7 3 1:35.7676 0:02.9979
5 57 MX5 Vic Peter PHILLIPS (1) Mazda MX5 A1 9 6 1:35.9733 0:03.2036
6 610 MX5 Vic Gary PRESCOTT (1) Mazda MX5 A1 9 5 1:36.9150 0:04.1453
7 141 MX5 Vic Max LLOYD (3) Mazda MX5 A1 8 5 1:37.6866 0:04.9169
8 44 AROCA Spaniard Ep3 (4) Honda Civic A1 9 6 1:37.7040 0:04.9343
9 64 AROCA Joe FALCONE (2) Alfa 75 TS M3 9 6 1:38.1217 0:05.3520
10 62 MX5 Vic Noel HERITAGE (1) Mazda MX5 A1 5 5 1:38.5161 0:05.7464
11 7 AROCA Robert VODOPIC (4) Nissan Pulsar A1 9 5 1:38.7760 0:06.0063
12 83 AROCA John CUMMING (2) Alfasud Ti M3 6 3 1:40.2719 0:07.5022
13 511 AROCA Phil AARONS (4) Alfetta GTV TS R3 7 3 1:42.1427 0:09.3730
14 78 AROCA Andrew HARVEY (4) Toyota Corolla A1 8 8 1:42.3987 0:09.6290
15 271 MX5 Vic John STONE (3) Mazda MX5 A1 6 6 1:42.6204 0:09.8507
16 36 MX5 Vic Paul MURPHY (3) Mazda MX5 A1 7 6 1:43.2089 0:10.4392
17 130 AROCA Tony RADITSIS (4) Alfa Guilia Super R3 8 5 1:43.5482 0:10.7785
18 139 PCCV Reg POLSON (3) Peugeot 205 GTI A1 8 6 1:43.6692 0:10.8995
19 19 AROCA Dominique CHALEYER (4) Alfa Giulia Sprint M3 8 8 1:45.4601 0:12.6904
20 18 AROCA Richard OUTRAM (4) Alfetta 1.8L M3 8 8 1:45.6481 0:12.8784
21 47 AROCA Oriano RIZIO (4) Alfa 105 GTV M3 8 8 1:47.8121 0:15.0424
22 135 AROCA Nicholas GRIGG (3) Mazda MX5 A1 8 7 1:48.0573 0:15.2876
23 41 VHRR Michael BAN (4) Sunbeam Alpine A1 8 7 1:52.0873 0:19.3176
24 4 AROCA Vince SARTOR (4) Alfa Guilia Super M3 1 1 2:12.1397 0:39.3700
Here are some videos of the day. I couldnt get any in car as my mount broke as I was trying to set it up, so I gave my phone to my brother who used zoom on the phone which works shithouse.
http://www.youtube.com/watch?v=nwxrq...ature=youtu.be
http://www.youtube.com/watch?v=RFboKSE-Y88
http://www.youtube.com/watch?v=XdL5lQyXN5g
http://i1250.photobucket.com/albums/...819_092834.jpg
http://i1250.photobucket.com/albums/...819_092923.jpg
http://i1250.photobucket.com/albums/...819_092914.jpg
http://farm8.staticflickr.com/7246/7...064e50f3_b.jpg
Sandown120819-1628.jpg by ratalfa, on Flickr
http://farm9.staticflickr.com/8447/7...c062ff77_b.jpg
Sandown120819-899.jpg by ratalfa, on Flickr
props for racing your shit bro
Beautiful car man, and great improvement in your times over the day :)
Just wondering man, how do the Buddy Club RSD feel on the street?
Are you running different damper settings for street and track?
Hey thanks man. It was my first track experience in a car and not my usual go kart so it was fun along with learning how to start setting up the car.
The buddy Clubs RSD for street are ok. I find that even on low damper of 5 it can get a tiny bit bumpy, not uncomfortable although when you go over a bump as you have your foot pressed down on the accelerator you do tend to hop as your leg moves from the car going over the bump which gets annoying as hell. Other than that I notice the perches come loose all the time but its a trade off with all coilovers.
With the damper it depends on what you want to run on the street. At Sandown coming off the last corner onto the straight I had to drop some stiffness off the front cause the car would hop over the many bumps and lose traction.
So small update atm.
Getting ready for Sandown track day in a few weeks.
Received my Schroth racing harness today so got to work installing it.
Was a pretty simple install that installs to all the OEM locations so no need for a cage or harness bar.
The rear bolts into the stock OEM seatbelt locations under the seat.
http://i1250.photobucket.com/albums/...ps1badcb5b.jpg
http://i1250.photobucket.com/albums/...ps01ee0145.jpg
While under there I discovered a little bit of a surprise....
http://i1250.photobucket.com/albums/...ps8bb649ea.jpg
Im now 200 yen richer! Will be there for a year so got some free spending money :p
With this model harness you can detacth the rear from the front with a buckle and leave it there so you can still take rear seat passengers and take the front belt off for daily if you want or just throw it around the back of the seat.
http://i1250.photobucket.com/albums/...psc80c9656.jpg
http://i1250.photobucket.com/albums/...psfeee65dd.jpg
And finally installed. The side bolts straight into the stock seat.
The only thing I had to do was disassemble the front straps and feed them through the stock holes at the head rest and then re do them up. Was scratching my head for a few mins trying to figure out how to take them out but reassembling was easy.
http://i1250.photobucket.com/albums/...ps35846934.jpg
They hold really tight so will be much better than using the stock belt for the track.
My only complaint was that I wish they had about 60 or 70cm more belt as Im pretty slim, except for the gut so that limits your seating adjustment just a tad but overall very happy with the belt, features and price.
Few more updates will be coming soon if I get my parts here on time.
oh nice... i didnt think you could get racing seatbeat things with ur back seats still intact..
awesome!
i've got an question for your BYP Ti exhaust..
is it noticeble louder when you drive normally?
It depends on the type of belt you buy. Some will only have the roll bar or harness bar attachments only. I bough this one for that reason plus its a Schroth.
With the exhaust, its not really loud at all when normal cruising, you will get a bit of noise on take off depending on how hard you push but I drive up to 4k with hardly anything but a low rumble. You get more noise when taking your foot off the accelerator.
But its loud as fk when you wind it out. So compared to stock under normal circumstances it is definitely noticeable.
hey mate after further use with the exhaust my recomendations is dont get it. It hangs too low gets brittle with heqt and a whole lot of of shit thats wrong with it. Sent byp a email but no response. Spend your money elswhere its not worth two cents after the shit i gone throught with it.
What happen?
As i said before, the exhaust hangs way too low even with my conservative height and 17's. I scrape over all speed humps. The titanium being so thin walled will then get brittle as heat goes through it. It get so brittle that a small scrape over a speed himp turned into a hole, now that hole is the size of a golf ball as the metal just gets brittler and brittler amd weak, to the point now that i have a large crack running up from the hole tote top of the pipe. If i wanted to i could just crustily bend it in half with no force . Not one bit happy at how it that mid pipe was designed. even looked at rps.13's exhaust with smaller 16's and a much much lower height than mine and he still had shitloads more clearamce than me. Sent from my phone so crapload of spelling mistakes but the least of my problems.....fuuu
Got a side profile of the car to show how much lower the exhaust sits from the chassis? I know a lot of exhausts designed for EP3/DC5 hang lower because otherwise they hit the chassis. My TODA exhaust b-pipe is easily the lowest part of my car too. Sits about 80mm off the ground whereas my front lip sits about 100mm off the ground.
Yeah, but it doesnt have anything to do with the diameter at all just that it wasnt bent to the exhaust tunnel shape like it should have. Yep its all cracked and fckd now if you must have it jist get the muffler and fit a SS mid pipe thats made by a reputable brand or get custom made Ti not worth it IMHO and im completly pissed off and dissapointed at byp amd still no response from them at all yet about it.
