K swap is a new kettle of fish and it gets expensive quickly. IMHO. K swap is a little more for the serious enthusiast.
The only real main reason of rebuilding the B20, is to do the conversion properly and do it once. B series engines are nearing on 15years old now so they are starting to get a little tired. It would be ideal to build that engine with some goodies here and there while you freshen it up for better power/reliablity also.
You don't need much to be very happy with a 2.0L going from a 1.6L. Most people rave about it and they are going from a 1.8!
i'd also like to know about the brakes. would it be a legal requirement for a brake upgrade?
if you got drums then ye.. but for lets say em1 no they are fine
I've seen cars engineered with drums on the rear still.
Most of the braking is done via the front so if you can get a good set of pads in there, you're fine. That "brake upgrade" rule is used a little too loosely, we are not engine swapping some 500whp engine in.
just curious, if u already have a b18c is it better to bore it out, sleeve it and run 85mm pistons or do a B20VTEC ?? would the results be similar?
gives you 1980cc compared to 1973cc's to begin with
is the ITR crank better to use in a b20 build?
I will be rebuilding my b18c7 soon -- but want more than 130-140kw@wheels. thinking of going to 2L or *gulp* lower compression charger build.
Same thing, but you will find B20vtec will save you BIG time - NSYPYRE
No, ITR crank is 2mm shorter in stroke. So stick to the B20 thumper - ewendc2r
ok thanks -- read somewhere about the itr crank being fully counter-weighted and assumed the other models werent.... thought this might be better in achieving higher rpm capability / less vibration etc..
so im likely better off putting my itr engine aside for the time being, building a b20 slapping that in and then just rebuilding the b18 and selling??
Both the ITR & B20B cranks are full counter.
For a roadie, use the B20 crank. In a race engine, IMO, you're better off with the 87.2mm stroke & narrow R bearings of the B18CR crank.
+ The B20 crank needs more balancing attention than the B18CR crank & is more prone to 2nd order harmonics @ over 8800rpm+
