oh ok .
casue my mate had d same setup and he said 11psi should be d limit.
so i guess thats what i should be aiming for then.
oh ok .
i'd stick to 10PSI if you want reliability as boost can spike here and there
weq ran 12 psi all day every day.
From what i worked out before i sold my car.
i had an eboost so i would have had 3 settings.
I would have run 7 for normal + rain
12 for a squirt.
14 for a run down the strip.
Boost doesnt kill ur motor its the power. (obviously within reason)
I'm running 11psi
Not stable all the way to red line and ends up being 9-10psi
Once I get e-boost I'll keep 11psi and it will stay that way throughout the rev range
If its dropping off to 9psi at redline, i can understand you wanting more. I went through a few boost controllers till i found one that held to redline. The td04 is a really badly designed turbo IMO (laggy, not enough power, wastegate port sucks). U can feel the flow. At 9psi, it wont pull all the way till redline. it needs to be making 10+psi at redline for the torque not to drop off..
Umm you want more power without turning up the boost... Look at a zex 53900 cam. DOesnt take too long too install. What else, water/meth injection. Im thinking about doing this too my 350z. The meth increases the fuel octane too 105-115 depending on mixture, cools your IATs by 20-30degs and signitificaly reduces detonation threshhold.... the injection kit will add 10-20kw.
wat price we lookin at for this injetion kit?
+ war controller u using?
There are lots of kits out there man. aquamist is nice for something complete.
lol I always want more but yeah I've been thinking about 53900 before ever boosting but thought that this turbo would run out of gas with the added power in the higher rev's?
Is it worth installing with out upgrading the value train? I know one for the ZEX cans can be installed without upgrade but don’t remember witch one..
Is the water/meth injection legal?
any1 got a link on these kits?
damn, heavy on d pocket.
so wen u say 10-20kw. ...
atw ?
also. after u get this, do u need to use special fuel ?
