lolz we had this chat at the start of this topic... yeh it sux about the d series, shes a awesome engine just yeah.. its more economical/practical to work on the b's...
but if i had a jdm d15b on the other hand...
Well I've just been looking through the 1/4 mile times on d-series.org here and the times are between 14.5 and 16.5 seconds on adverage.In a b18c7,your looking at mid 14's stock right?
If this is correct then (as usual ;) ) you are correct.
Taken from the same thread-
"Anyone in the 13's on this board? I've seen with my eyes, a 88' HF: D16A with ZC pistons, stock Y8 head, I/H/E, VAFC and AEM cam gear go 13.20's at 99mph on BFG's. Hard to believe but trust me, seeing is believing.
Sam"
so thats using drag radials i suppose and probably stripped to the max... hehe.
on the onecamonly.com boards, SOHCinWA manages a 13.95 second pass with full interior, and theres an EG using a stock d15b motor with minor intake and exhaust mods running in the 13s (stripped out of course).
im just waiting for a throttle linkage so i can finally get around to fitting my twin dcoe40 carbs to my d15b.
modifying a d series all depends on what you consider a small fortune. bisimoto's first d series build was a street legal crx i believe that ran 12s with only $3000 put into it (using drag radials).
altho right now, considering the state of the australian economy, its getting more expensive to import parts from america, im lucky i managed to get most of the parts for my build before the economy died.
The cheapest way to a bit more power on D's would be....
Zex 59300 cam and spring/retainers tuned with Hondata
And if it's a y4 (non Vtec) go for a bisimoto re-grind cam,springs and retainers and tune with greddy e-manage.
hondata on a y4 is so not worth the trouble
greddy it will have to be...
Hondata won't work on a automatic either (not that anyone has an auto except me :) hehehe)
how about greddy emanage ultimate? can that adjust rev limiter? im assuming you're referring to greddy emanage blue
