I've uploaded pics of the new replica grille and how well it fits. My father and I came to the conclusion the reason why the cheap replica one didn't fit was because the mesh had already been fitted and was very very poorly cut. As a result, the mesh was "bending" the plastic, hence causing it to not fit.
Lesson to be learnt: If you're cutting the mesh for the grille- DO NOT USE THE ORIGINAL CRAPPY MESH AS A TEMPLATE
Here are some pics;
http://img213.imageshack.us/img213/7...diumdh3.th.jpg http://img441.imageshack.us/img441/2...diumnj4.th.jpg
More can be found at http://picasaweb.google.com/jace.88/08JACE888Stage2
Sorry for not so great quality; was using a camera phone inside the carpark. Also note, it's still the original dull black it came in- I haven't spray painted it to colour match the rest of my car. But from afar, it looks stock and the lines are quite flowing with the bonnet, so it doesn't look out of place :)
ps. Even though Mugen is great quality, I refuse to believe that the front grille is worth $500+ AUD. But then I also am shocked to find that the cheap grille (my first silver one) probably isn't even worth $50. As a tip dyljoy, you can try taking off the mesh, buying proper mesh and cutting it again, and then also using the 3M double sided foam tape to help hold it in firmly; however, this all depends how good quality the plastic used to make the grille is... my second (black) grille was considerably more durable/stronger than the first one despite both claiming to be made from ABS Plastic.
