uhm.. imnot so experienced with where a clutch cable should be at? drivers side or passenegrs side?
driver side my fren, the pedal next to the brake!!on the left hand side of the brake!!well for a manual car that is
oh so the cable is actually up there? lol.. soo there shud be a grommet or plate there where i can drill into? ahh sweet. cheers for the help mate =D.
thanks for the info re sway bars guys.
To black8thgen, you can try running the cables from top left side of engine bay (facing the front of the car), the cables actually run right above the driver side wheel arc, very tricky but am sure you can figure it out.
Inside the car on the driver side, there is a thumb size hole some where behind the fuse box (which is to the right of the accelerator paddel, you need to pull out that plastic cover). You won't be able to see it because it sits so deep inside, but if you put your hand in there with alot of patient you will find it with your finger. Have a mate feed a thin cable down first, and you put a finger down there and try to "grab" it, very tricky but safer than drilling. Then tie the thin cable to whatever cables you want and pull them through the arc and the hole. Very confusing i know but you gotta try it to understand... hope this help.
ahhhh. yeah thanks buddy ill definately give that a go =D.
+1 on that. that's pretty much the same route for when my friend and i did the wiring for my foglights. it comes in through the lil hole near the fuse box and up to the panel (or hole just beneath the select/reset mileage button is) to where my foglight switch is.
do u guys have pics of this hole? might help when i get my foggies lol
ps - i left my phone at home, thinking of getting some stickers made 2moro wanna come leo?
got sprint booster installed today! extremely happy with the result, might get a little too sensitive when accelerating from stop, but its not a worry, just needa get used to step on the pedal a little bit softer... but anything from 2nd gear is great, u feel the torque comes earlier...
installed cusco rear sway bar and tanabe sustec pro-nf.. its lowered.. we'll give a review later on and pics up sometime this week when i get the chance.
note-to-self: pump up tyres, clean car lol
u back in bris yet watermo?
YES IM BACK lol, finally can put the parts onto the car! Mugen visor installed too, took me ages to rip those window seals rubber down n get those clips inside -_- will probably install the HID sumtime tmr
