Dedicated DA9 Q & A thread
	Quote:
				Originally Posted by
hondapop
			Don't know about the check light's relationship to a faulty fuel pump, otherwise it sounds like that old bug-a-boo, the main relay (which also controls the pump) soldering getting dry joints.
 The check engine light turns on when u turn ignition to accessorize then off when the pump has primed the lines
Ahh ok so I need to re solder the main relay ?
Sounds about right to be some elec bug lol
I can hear the pump priming most times , but when I don't hear it prime it either won't start or start then die
		It's a DIY job mate, my car was acting the same , then I removed all the old solder then re soldered the main relay and since then it has been awesome , you only need like 3-4 tools and you can do it yourself !!
Or could take the part out and take it to an auto electrician to do for u but I would try do it yourself =)
Also look up "integra main relay problem" on YouTube to find a walk through guide on how to find the main relay (behind coin slot) , remove it , de solder it ,  re solder it , then reinstall it ,
Since I fixed mine it hasn't not started once
