I haven't got one yet, but are you formatting your 4GB USB key as FAT32? (not NTFS?) just a stab in the dark but could be a reason why?
Anyone used to Neo link before? Going for around $320 for the unit and it offers full controls on the wheel etc. This is for Ipod. Can also choose a USB option. Why is it so expensive compared to Xcarlink?
I got my replacement Chinese Xcarlink today... works a treat with a 4GB Kingston USB stick... have yet to try with an 8GB and 16GB but I do have one each lying around somewhere.
Bought Xcarlink today should receive it next few days , can it be installed throught glove box (CL9) did not want to remove head unit . anyone have any idea how to remove glove box ?
you must remove the head unit to install it.
No. You do not have to remove the headunit itself, you just need to remove the centre console below it and then you will be able to see the CV changer plug where you need to plug your xcarlink on the bottom of the headunit and you can easily reach it without removing the headunit itself.
I find mounting the xcarlink in the centre console below the headunit its much easier than the glovebox but you can try any other location really as long as your wire is long enough - be inovative :)
+1, the centre console is a hassle free place to put it. If you feel up to the task, grab some panel mount plugs off the net, drill some holes in the side of the centre console and run the usb and aux in plugs through the console wall, hiding the unit itself underneath.
That's what I did, hardest part was drilling neat holes as the console wall is about 5mm thick!
Looks very tidy now though :thumbsup:
how do you remove gear knob on (CL9 2006) is it just screwed in place , my has hard plastic just below gear knob ?
You can just pull the leather off be gentle but firm
whats better through the glovebox or... anyone know a place in melb that will do it im scared i will break something.
Ill do it for 50 pm me is yours manual or auto
