FWIW, Peng's car will make more power with a better intake & cat.
That is remove the factory airbox & filter & replace it with something better. (Injen, AEM, Mugen etc...)
The cat is still a ceramic unit also, there's probably a bit of power hiding here too.
The cam timing, though on zero's seems to be pretty much right with a clean smooth Vtec swap @ 6500rpm. (which is odd)
As a side note, if I was to guess the cam spec by how it tuned, rather than be told what they were...
To be honest I would have guessed them as Pro 1's rather than Pro 3's.
Just by the charaterisic of the output more than anything else.
That said, we've never seen Pro 3's used in this type of combination previously.
Other notes of interest,
We've never really seen more than 120~122kw @ the wheels using the OEM DC2 airbox.
Changing the filter to a high flow item does little or nothing to improve this due to proximity of filter to airbox inner surface.
