do it for 30!
Jokes
do it for 30!
Jokes
how does the GROM units differ from the xcarlink?
I've got a USB with 3 folders, CD01, CD02 and CD03. 1 and 2 work fine, but 3 doesn't show up? Idea's?
What format are the files in CD03 in? You can only listen to wav, mp3 or wma IIRC.
Mp3 - just like the other two folders!
Try renaming your folders to see if the offending folder will show up in your car if it is a different numbered CD.
Yeh I tried renaming CD03, CD02, and also changing CD02 to CD03. Then it means I can listen to CD01 and CD03. Something must be amiss with the one folder, but for the life of me I can't work it out!
Hey guys just got the xcarlink installed for my 2006 euro luxury. it works perfectly but the light on my heated seats button (hi and lo plus the chair icon) doesnt light up anymore and also my cigarette lighter and the ash tray console :(. Anyone have the same problem or solved the problem? Thanks
Sounds like you forgot to plug everything back in when reattaching your ashtray.
ive had this problem... the light globe has blown... on my euro now.. driver side high light aint working... its real sensitive...
Everything was plugged in all those things mentioned just stopped working. Il check the light bulbs when i have time
Got a question to anyone running the xcarlink usb setup with a bluetooth dongle.. Does the bluetooth plug into the front or back of the kit?
I plan fitting mine in the compartment under the radio, but was wondering if it would be possible to run the bluetooth cables and mic through the back and then mounting the mic somewhere..
Just want it to look neat, hope someone can help
