had a go with one yesterday but he denied that the ep3 was quicker lol
Ohk,
thankyou Boys!
this one sounded worked and i was on his ass and getting closer. the EP shifts faster which i think helps alot
S2000 and EP3 are both designed for different purposes. even tho they both were born for track use, S2k is also more of an high class/elite roadster. so tuning and engine will be different.
Whereas Type R was born for track use, thats where the red 'H' comes into play :D
oh, BTW its spelled as VTEC, not V-tech (just for an input):thumbsup:
^ i must add though, MzS200 the s2k might not be the FASTEST thing on the road (although they do pack a punch) its got the highest power output per litre of a production engine in a car <$100,000, so maybe thats what your friends mean?
but as we all know from experience, power doesn't necessarily = speed, especially on the roads.
Haha nice!
I applied the badges after a car wash last night but I can't put the front Type R badge on because I need the push-nuts that hold it in place from behind the grill. I'm going to look at a hardware store later on and see if I can find some that will fit, but do you know if you guys have them there at Honda? (I know it's a bit of a longshot to know this off the top of your head!)
Thanks.
-J
Really depends on the driver, if its 2 good drivers the s2000 will take off better as its a rear wheel drive and traction for a better take off will be better, but saying that the ep3 takes off very well if you know how to do it and the short gear ratios help it get to where you want to be very fast. if your worried just dont dump the clutch on take off "ride" it abit so it dosnt bog down and you shouldnt have any troubles... and never fill your tank more than half, and leave the rear tyre pressures 5lb lower than the front in the wet :)
is installation of a aftermarket rear tiebar straight forward?
thinking of getting Beaks one from JDM yard.
Is there any noticable gain or benefit from this?
