ahaha seems about right guess 335 pages cant be wrong about the car. are you importing one?
They might look plain initially but it'll grow on ya.
Im facing some issues with my new ep3.
when i slightly turn my steering wheel to the left there are some light clicking sounds?
does anyone know what the issue is?? is it the engine mount??
Hey guys, I suspect my engine mounts are on their way out.
This may sound a bit n00b, but to fix this, is it possible to put motor mount inserts into a damaged engine mount to fix it? Mines is OEM. Here it said that you could, but only if no metal is broken. Is this right? Is there a way I can check this myself?
Or should I just do it right and replace all the engine mounts with Innovative ones (with 60A red bushings for daily driving's sake)? Thoughts on the Innovative mounts, guys?
Also, Neo, read last week that you may be organising a deal on disc and pads. Is this still happening? Just thought I'd express my interest. :)
There are only inserts for the front and rear mounts. The most common mount to go is the drivers mount (which you cannot cheap fix). And if you drag or track the car, the side mounts will help with wheel hopping, especially if you do hard launches!
I had 75A (Too harsh), now have 60A (Still a little harsh) but its a good compromise.
With the brake stuff, need to finalise a deal on the pads, most probably today :)
