also went to charlies at yennoora there was a B20VTEC crx with jun spec 3 head 12+ compression anyones on here? how much kw out of that beast?
if the ratios are different then yes output will be different. If ratios are the same, then the same output.
by example, a longer final drive (i.e. a 4.9 vs a 4.7) will increase the torque at the wheels but reduce top speed.....
Would make little difference on a dyno though....
the difference would be entirely relative to the change in ratio - but yep, i see the point above.
I went through the whole thread but found NO information on the PCV system for B20 vtec.
Breather kit is a good start. Anyone got pics how its connected?
There has been a few good discussions about PCV setups in a few of the older B20 threads.
Here's a few posts that were made awhile back in my build thread..... not sure how helpful it is but Im sure others can expand further on some of the points made
Also, here's more info on the setup I was running on my B20VTEC....
Quote:
Originally Posted by ZeForce
RE b20's.....cant you just take the breather / oil seperator system off another b18c or b16a and run that like OEM ?
thanks thats the exact answer why ! :)
nice info there Zeforce
Hmm so what will happen to the inlet on the Intake mani where the orignial pcv hose connect to? Do you block that off?
Instead of taking both hex plugs off, cant u just take one off and use the other one on the IM via the breather kit?
That way the PCV system will be close to stock
I just blocked off the port on my IM, otherwise I would have removed the filter from the top of the breather tank and ran a hose to my IM with a PCV valve. Also, you dont need to use both hex plugs but I used one as a drainage so I didnt have to worry about emptying it out and should also help the crankcase breathe more.
As they say there is more than one way to skin a cat....
