Originally Posted by
RPS.13
Cool j's tie rods, then you can go to town with the front camber adjustment without any worries. Awesome :thumbsup:
Rear camber, I'd just set it until the tyre no longer scrubs. I normally just check it by eye and kind of draw an imaginary line as to where the tyre will travel upwards under compression. Drive check the clearence and adjust accordingly.
They probably didn't do it, just as a side of caution to cover themselves. Say if anything went wrong. Google: wheel bearing failure danger, that should answer your question.
You could get it aligned and change the wheel bearing later. But obviously don't wait too long to do it.
Whilst your at it, you could look into changing your LCA bushes and roll center adjusters. Whilst the hub is out.
