thanks for the link didz!
not much difference in the dyno sheet between the spoon and toda...
what are the price differences though, and also with spoon you gotta buy a spoon cat aswelll is that the same with toda ? if so how much is it all, put together and which one is cheaper ?
since toda and spoon are made from JAPAN you are require to run a jdm cat or a aftermarket cat which everyone tends to do
I'm getting a set of Toda headers for our DC2R in the next month or so, will get it ceramic coated and an aftermarket cat to suit. Most likely to go for the MetalCat with flanges to be welded on by the exhaust shop we use a lot.
Will post some pics once they are installed onto the car.
Heard that "someone" might be comparing all different brand headers very soon. Back to back dyno readings. :P.
Shit when is that happening? That will be exciting, any donations of particular header needed?
DTM headers...:thumbsup:
SMSP/Hytech :thumbsup::thumbsup::thumbsup:
xforce ftw
if your interested in a high flow metallic cat, lemme know i have a really good source and for a damn decent price brand new... say 1/4 price of catco/metalcat
tested it at the exhaust shop before fitting the catback... gets red hot very quickly on idle... but then again mine was heat wrapped so that may have helped also.... but it's a good sign that it will function good....
